2001 Chrysler PT Cruiser Overheats
69VETTE
i have a 2001 pt cruiser that keeps overheating. i have changed the water pump,pain in the neck to do,changed the thermostat,radiator.no water in the oil.comp. checked all cylinders.150psi in all of them.the fan runs when car parked. i start driving and the car starts overheating after 5 minutes of driving. any ideas?
jim
2001 pt cruiser 90k miles 2.4 moter
Feb 22, 2007 at 5:44 AM
MIKE H R
  • 3,094 POSTS
sounds like it has a restricted circulation. what about the radiator cap did you replace that to? could also be vapor locked.
Feb 22, 2007 at 8:33 AM
  • 75,988 POSTS
Blown headgasket sometimes don't show in the oil or coolant for a visual check-to rule out headgasket sniif the radiator for HC thru the of a Gas Analyzer or Chek Bloc-
Rad cap and Air lock could be it.
Feb 23, 2007 at 2:38 PM
Suggested Repair
Check the radiator cap and bleed any air lock or restricted coolant circulation. Also test the radiator coolant for exhaust hydrocarbons with a block tester or gas analyzer to rule out a blown head gasket that may not show in the oil.
Conversation Summary
A 2001 Chrysler PT Cruiser with a 2.4L engine overheats after about five minutes of driving despite a new water pump, thermostat, and radiator. Compression is even, there is no coolant in the oil, and the cooling fan runs when parked. Replies suggest restricted circulation, a bad radiator cap, an air or vapor lock, or a head gasket leak that needs a combustion-gas test.
