2004 Chrysler PT Cruiser Torn CV Boot Fix
DAVID NOFTSKER
I have a 2004 Chrysler, P.T Cruiser 2.4 turbo w/o sport suspension
automatic transmission, 128,000 miles runs fantastic!!!
but while replacing the right front strut I did not protect
my C.V. axel boot and I tore the outer boot. I purchased a split boot however it does not fit tightly and is still leaking. I have never taken a c.v. axel apart is it easy so I can put on a one piece boot or with the amount of miles on the axel would it be best to just replace the complete half shaft.
thx David Noftsker :oops: :oops: :oops: :oops: :?: :?: :?: :?: :?: :?: :?: :D :D :D :D
Sep 10, 2007 at 2:48 PM
2CARPRO JACK
  • 11,533 POSTS
128k.... replace the axle. They have become less expensive than they once were.Depending on cv design, you may have to take one end off to replace the boot on the other end, now you have replaced 2 boots on an axle with 128k
Sep 11, 2007 at 12:54 AM
Suggested Repair
Replace the complete CV axle/half shaft rather than installing a one-piece boot. At 128,000 miles, boot replacement can require removing one joint to service the other, so a full axle is the more practical choice.
Conversation Summary
The owner of a 2004 Chrysler PT Cruiser tore the outer CV boot while replacing the right front strut. A split boot does not fit tightly and still leaks, and the owner asked whether to install a one-piece boot or replace the half shaft. The expert recommended replacing the axle at 128,000 miles because axles are relatively inexpensive and boot service may require disassembling both ends.
