Thanks,
Mike
PT Crawler :?
Do not accept an extra 5 hours just to remove the passenger-side motor mount. On this PT Cruiser, the timing belt job is tight and may need special tools; about 3.5 hours is typical for the whole job, with 5 hours as a maximum. Compare shop quotes and have an experienced technician do the work unless you already have timing-belt experience.
The owner of a 2001 Chrysler PT Cruiser automatic asked whether the upper passenger-side motor mount must come off for a timing belt replacement after a shop quoted an extra 5 hours, noting the mount appears attached to the timing cover. The expert said access is tight and special tools can help, but 5 hours is not realistic for the mount alone. About 3.5 hours is more typical for the complete job, with 5 hours as a maximum, so the owner should compare prices and use an experienced shop if unfamiliar with the work.
