1998 Dodge Neon Firing Order
CHRYSLER
LYNDALE
Can anyone tell me what the fireing order is for a
98 Dodge Neon.
Thank You very much.
Lyndale
Feb 10, 2006 at 2:09 AM
PEPPERMRJ
  • 1,158 POSTS
2.0L Engine Firing Order:1-3-4-2 Distributorless Ignition System
1-----------------4
--ignition coil-----[connector side]
2-----------------3
[1----2----3----4]
-Front of block
Feb 12, 2006 at 3:34 AM
JDL
  • 16,098 POSTS
Click on the link, the front should be the end with accessory belt.
http://postimage.org/image/o4864tvo/
Nov 21, 2010 at 11:50 AM
Suggested Repair
For a 1998 Dodge Neon 2.0L, use firing order 1-3-4-2 on the distributorless ignition system. Coil terminals are arranged with cylinders 1 and 2 opposite 4 and 3, connector side toward 4 and 3; the front of the block is the accessory-belt end.
Conversation Summary
The owner asked for the firing order of a 1998 Dodge Neon. An expert stated the 2.0L distributorless ignition firing order is 1-3-4-2 and described the coil terminal layout. A second expert said the front of the engine is the accessory-belt end and linked a diagram.
