2000 Dodge Neon Oil on Spark Plug Tip
CHRISTOPHERM
I have a 2000neon I have a 2.0 engine standard I have recently replaced the valve cover gasket thinking that would correct the issue but it has not my 3 cylinder is fouling out. I am not getting oil our side the spark plug chamber but when I pull the fouled plug the tip is covered in oil I assume that is why the engine is misfireing and has a reall ruff idle and bogs out after a stop. Any suggestions how to fix this issue?????
Sep 5, 2007 at 2:36 PM
  • 75,988 POSTS
[quote:443e9029b3="christopherm"]I have a 2000neon I have a 2.0 engine standard I have recently replaced the valve cover gasket thinking that would correct the issue but it has not my 3 cylinder is fouling out. I am not getting oil our side the spark plug chamber but when I pull the fouled plug the tip is covered in oil I assume that is why the engine is misfireing and has a reall ruff idle and bogs out after a stop. Any suggestions how to fix this issue?????[/quote:443e9029b3]
Major repair could be Valve Job/Re-ringing of the cylinders or reconditioning.
Sep 6, 2007 at 7:11 PM
Suggested Repair
Oil on the plug tip rather than in the plug well points to an internal oil-control problem. A valve job, cylinder re-ringing, or engine reconditioning may be required.
Conversation Summary
The owner of a 2000 Dodge Neon 2.0 reports that the number 3 spark plug tip is covered in oil, causing a misfire, rough idle, and bogging after stops. The valve cover gasket was already replaced, and oil is not appearing outside the plug chamber. The expert says the repair may require a valve job, cylinder re-ringing, or engine reconditioning.
