2000 Dodge Neon P0340 Cam Signal
BOBO
I have two trouble codes ,1684 and 0340.
Can someone help to what they mean.
Thanks.
p.s.
Thanks for the info on the spark-plugs
Bobo
Jul 23, 2006 at 1:08 PM
MIKEYBDMAN
  • 623 POSTS
[quote:256766d36d="Bobo"]I have two trouble codes ,1684 and 0340.
Thanks.
p.s.
Bobo[/quote:256766d36d]
P1684 just means the computer memory has been cleared lately. It does not indicatoe a problem.
SYMPTOM
P0340 - NO CAM SIGNAL AT PCM
WHEN MONITORED
During engine cranking, after 32 crank position signals.
SET CONDITION
No Camshaft Position Sensor signal is present with crank signal.
POSSIBLE CAUSES
Target magnet defective
Sensor ground circuit open
Wiring harness intermittent defect
Stray signal from the crankshaft position sensor
Irregular LAB scope pattern of CMP signal
CMP signal circuit open
CMP signal circuit shorted to ground
CMP signal circuit shorted to sensor ground circuit
8 volt supply circuit open
8 volt supply circuit shorted to ground
8 volt supply shorted to sensor ground circuit
CMP sensor defective
PCM defective
PCM defective (8 volt supply)
8 volt supply circuit shorted to voltage
CMP signal circuit shorted to 8 volt supply circuit
CMP signal circuit shorted to voltage
Jul 23, 2006 at 1:18 PM
KARENCAREN
  • 72 POSTS
That code will give you some work to do. Thats how many you should check to get that code gone.
Mar 2, 2009 at 12:09 PM
Suggested Repair
Treat P1684 as informational only: it means PCM memory was recently cleared and does not indicate a fault. For P0340 (no cam signal at the PCM during cranking), inspect the camshaft position sensor, target magnet, sensor ground, signal circuit, and 8-volt supply for opens, shorts, stray signals, or intermittent wiring before considering a defective PCM.
Conversation Summary
The owner of a 2000 Dodge Neon asked what trouble codes 1684 and 0340 mean. An expert explained that P1684 only means the computer memory was recently cleared and is not a problem. P0340 means no camshaft position sensor signal is present at the PCM during cranking, with possible causes including a defective CMP sensor or target magnet, open or shorted signal or ground circuits, an 8-volt supply fault, intermittent wiring, or a defective PCM. Another user noted that clearing the code requires checking those items.
