1999 Dodge Neon Cloudy Headlight Lenses Fix
GRAMMAJ
I have a Dodge Neon 4 door 1999 with 120,000 miles on it. My headlights aren't very effective due to the cloudy lens cover. How do I take it off and wash the cover without upsetting the beam adjustment?
Dec 8, 2006 at 10:18 PM
BOOTDOG
  • 665 POSTS
when the lenses get cloudy, you can't wash the cloudiness away. the only way to fix the problem is to replace the lenses. off hand i'm not sure how to tell you how to remove them without me being there to see how they come out. just take your time and makes sure that if the adjustment gets tampered with then you'll need to have them aimed. hope this helps a little :)
Dec 9, 2006 at 3:03 AM
Suggested Repair
Replace the cloudy headlight lenses; washing will not remove the cloudiness. If beam adjustment is disturbed during removal, have the headlights aimed.
Conversation Summary
The owner of a 1999 Dodge Neon with 120,000 miles asked how to remove and wash cloudy headlight lens covers without disturbing beam adjustment. The expert said the cloudiness cannot be washed away and the lenses must be replaced. No removal steps were given; if aiming is disturbed, the headlights should be aimed.
