Can anyone tell me what the fireing order is for a
98 Dodge Neon.
Thank You very much.
Lyndale
98 Dodge Neon.
Lyndale
Feb 10, 2006 at 2:09 AM
For a 1998 Dodge Neon 2.0L, use firing order 1-3-4-2 on the distributorless ignition system. Coil terminals are arranged with cylinders 1 and 2 opposite 4 and 3, connector side toward 4 and 3; the front of the block is the accessory-belt end.
The owner asked for the firing order of a 1998 Dodge Neon. An expert stated the 2.0L distributorless ignition firing order is 1-3-4-2 and described the coil terminal layout. A second expert said the front of the engine is the accessory-belt end and linked a diagram.
