1974 Dodge Challenger Stalls on Throttle
CHRYSLER
HDCRAZYHOMBRE
I have a tough question and I'm hoping someone here can help me answer.
I have a 74 Challenger, w/ a built up 383, backed by a 727 auto trans w/ 2800 stall converter, 3.55 posi gears.
Engine sounds mean while idling but when I stomp on the gas, it stalls out. I have plenty of fuel pressure (4lbs psi). Everything in the engine compartment is new.
I checked timing, swapped out carbs, ran positive wire from battery to coil, etc.
Any ideas? I'm at a loss...
Tim
Jul 26, 2006 at 12:17 PM
CARAVANOGRE67
  • 22 POSTS
My recommendation to you is get a high volume fuel pump . A big block needs lots of fuel and 4psi is no where near enough pressureto feed that motor. You should actually run a electronic fuel pump. Go to a Lordco dealer and ask what they recommend.good luck
Aug 2, 2006 at 4:39 PM
Suggested Repair
Install a high-volume fuel pump, preferably an electric pump, because about 4 psi is not enough to feed a big-block 383 under hard acceleration. Ask a parts dealer for a pump suited to the engine.
Conversation Summary
The owner of a 1974 Challenger with a built 383, 727 automatic, and 2800-stall converter says the engine idles but stalls when the throttle is opened hard. Fuel pressure is about 4 psi, and timing, carburetors, and the coil feed have already been checked. The expert says a big-block needs more fuel and recommends a high-volume electric fuel pump.
