Dodge going dead when i take foot off gas, in forward or reverse already changed idle air motor ,throttle position sensor ,map sensor.
Feb 6, 2007 at 2:32 AM
If the truck is an automatic, drain, flush, and refill the transmission, replace the filter, and add 2 ounces of Lube Guard. Degraded or overheated transmission fluid can stall the engine when the throttle is released in gear.
The owner of a 1998 Dodge Ram 318 with 130,000 miles says the engine dies when the foot comes off the gas in forward or reverse. The idle air control motor, throttle position sensor, and MAP sensor have already been replaced. An expert who had the same issue recommends a transmission drain, flush, fill, and filter change plus 2 ounces of Lube Guard, explaining that poor or burning transmission fluid can stall the engine.
