1987 Chrysler New Yorker car wont start
GARAG0
  • 1987 CHRYSLER NEW YORKER
  • V8
  • 110 MILES
The car has a new starter good baterie connections from starter to batterie seem to be ok. Turn the key I get a very faint click somewher allong fire wall that is it what do you think is wrong
Friday, January 16th, 2009 AT 5:26 AM
  • 109,885 POSTS
Hi:
If all is good, check the starter relay. I believe it is on the inner fender or power distribution box.
Saturday, January 31st, 2009 AT 8:03 PM
CARSANDAIRPLANES
  • 19 POSTS
I know this post is old, but I'll chime in. Try having a friend try to start the car and look under the hood on a dark night. The faint sound might be a spark from a loose ground wire (specially the one that attaches the solenoid to the starter housing). I know it seems unlikely with a new starter, but that is the first thing I would check. That is what I would check after verifying that, as Jacobandnickolas suggests, the starter relay is ok. You can do this with a multi-meter.
Monday, March 15th, 2010 AT 1:02 AM
  • 109,885 POSTS
Not a bad suggestion.
Monday, March 15th, 2010 AT 8:01 AM
