1997 Chrysler LHS to fix car
GRANTGARLAND
  • 1997 CHRYSLER LHS
Engine Performance problem
1997 Chrysler LHS 6 cyl Front Wheel Drive Automatic
my car is not starting thnink mite be fule pump or filter or Spark plugs. How wuold I tell the differce between them. The moter turns over but wont start like it not getting a any fule in
Friday, May 21st, 2010 AT 6:09 PM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 in away from ground have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors and computer. Note: If it doesn't apply disregard it
Friday, May 21st, 2010 AT 9:19 PM
