1997 Chrysler LHS car won't start
STUCKINPHILLY
  • 1997 CHRYSLER LHS
1997 Chrysler LHS 6 cyl Two Wheel Drive Automatic
I filled up my car drove home parked hour later would't start back up since then i've given the car a tune up
Tuesday, March 30th, 2010 AT 11:22 AM
Pick your symptom:
**Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada:
Could be the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Tuesday, March 30th, 2010 AT 4:36 PM
