Hmm, sounds like a possible issue with the wiring, maybe damaged harness/relay. Would check that.
Heres how to check fuel pressure.
Remove protective cap off of the fuel pressure test port, passanger side of fuel rail above thermostat housing.
Next attach fuel pressure tester and scan tool to obd attachment port.
Turn ignition on and activate asd fuel pressure test, next compare pressure to specifications, if good remove tool and your good to go.
If no pressure is present check the fuel pump wiring harness and fuel relay.
Let me know if its over specs or under, or none at all.
Engine off, ignition on fuel pump activate with scan tool should be 40psi.
Engine running pressure should be 39 with vaccum line on.
Engine running pressure no vaccum should be 48.
SPONSORED LINKS
Saturday, September 13th, 2008 AT 7:57 PM
