1990 Chrysler Le Baron starting issue. Again
NOTOP90
  • 1990 CHRYSLER LE BARON
  • 4 CYL
  • FWD
  • 195,000 MILES
I went thru some major questions and answers for this car already. Well, now I'm back to square one again. I couldn't get it to start for about three months or so, therefore I started changing parts left and right that had to do with fuel or starting. This is what has been changed in it. I replaced the fuel filter. Fuel pump relay. Battery. Had the starter tested ( which tested strong). And still it would not start. Finally, I figured out that my problem was the neutral safety switch. Which I also replaced. Well. The car was running for about a week. Now.I'm back to where I started. It will not start again, all it does is turn over but does not want to engage and keep running. All that happens is the starter cranking and nothing more.
Tuesday, June 3rd, 2008 AT 7:34 PM
2CARPRO JACK
  • 11,533 POSTS
Check for spark and fuel pressure to begin with. Find the ASD relay (auto shut down) and swap it with the a/c relay to see if the van will start. Seen a few ASD relays go bad keeping the van from running. The ASD relay is the one closest to the headlight on the drivers side inner fender
Wednesday, June 4th, 2008 AT 7:50 AM
NOTOP90
  • 8 POSTS
Hi, not really sure who you are replying to with your repair answer. The vehicle I'm having trouble with is actually a 1990 chrysler lebaron convertible car.
Wednesday, June 4th, 2008 AT 8:00 AM
2CARPRO JACK
  • 11,533 POSTS
My bad, previous post was for a van, still had that on my head. The info still applies just said van instead of car
Wednesday, June 4th, 2008 AT 10:40 AM
