1990 Chrysler Le Baron
JOHN36
  • 1990 CHRYSLER LE BARON
  • 6 CYL
  • 120,000 MILES
My car had stop running whn I was drivivg it when I went to start it back up it wouldnt start then it started but it was shaking then went dead, then wouldnt start at all then I did a tune-up an changed the thermostat, and the cat converter, and changed the fuel pump an the fuel sending unit an now when I start the car it runs fine until it get to the operating tempture it start to lose power and when I step on the gas pedal it start to putting then I let up of the gas pedal it surges the start to put and the rpms drops put when the car is in park it idolls fine what could be the problem
Wednesday, February 18th, 2009 AT 5:23 PM
THETOOLMAN
  • 123 POSTS
Did this car run hot? What caused the no start? If it run hot that could tell us more info to help trouble shoot your problem. Try to think about any and everything that got you to this point.
Friday, February 27th, 2009 AT 7:54 PM
