1977 Chrysler Le Baron I know this sound sketchy
LANCEK4
  • 1977 CHRYSLER LE BARON
1977 Chrysler Le Baron V8
I want to hot wire my own car. My car. I think it is ingnition switch problem and I want to by pass it. I have to fix it NOW. I do not have money to take it somewhere or get a part. I just want to know I can start the car when it doesnt start. All electric works, no lights dim when I turn ingition, just silence, no clicking, no 'nothing'. This happened occasionally only on mornings or at night. In the day it always started. Now it hasnt started in three days, then earlier it started, and now it wont. Had to tow it home. Im going to look at a Chilton and start crossing wires. I do not have the luxury of time or money. Anyone have any other ideas? The bus will not get me to work on time, too early.
Tuesday, August 31st, 2010 AT 12:41 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Maybe starter relay open hood find relay near battery silver box POS batt cable goes to it. I think small brown wire take screwdriver touch brown wire to POS cable. Hopefully start will crank. Operating from memory don't have schematics on the old of car but I was working on them back then.
Let me know
Thanks for donate
Tuesday, August 31st, 2010 AT 11:55 AM
LANCEK4
  • 24 POSTS
I guess I got two of you guys helping. The other guy said jump between POS bat to coil POS pole and short the relay. I followed the cable under the car and it goes to the starter and I cant get to it. I need a method that I can do anywhere anytime the car doesnt start. Can I cross the yellow and red under the sterring colum for the same result? Or Where is the relay? Is it on the fire wall? By the battery on top view of engine? Or underneath?
Tuesday, August 31st, 2010 AT 2:47 PM
LANCEK4
  • 24 POSTS
What is the relay? It is not the selinoid? Thats down on the starter. Right? It is up near the battery?
Tuesday, August 31st, 2010 AT 2:48 PM
LANCEK4
  • 24 POSTS
OK the brown wire goes fromt the battry to a small black box thing on the firewall. It plugs in there. There are also a number of plug/wires leading out of it. Is this the relay? Do I pull the plug out and short that plug to the coil pos post?
Tuesday, August 31st, 2010 AT 3:09 PM
