1997 Chrysler Concorde MY CAR OVERHEATS AND THE HEATER DOES
TASHAGODWIN
  • 1997 CHRYSLER CONCORDE
Heater problem
1997 Chrysler Concorde V12 All Wheel Drive Automatic
I HAVE A 1997 CRYSLER CONCORDE AND IT HAS BEEN IN SHOP MANY OF TIMES THEY FIXED THE WATER PUMP AND THEY PUT A NEW THERMISTAT IN AND IT WORKED JUST FINE THEN ONE DAY IT JUST STATED TO OVER HEAT THEN MY HEATER STOPED WORKING SOME ONE TOLD ME IT WAS THE THERMISTAT STICKING AND SOME ONE ELS TOLD ME IT WAS THE HEATER CORE? WHAT DO YOU THINK?
Friday, November 14th, 2008 AT 1:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
A stuck thermostat will cause the vehicle to overheat and make heater blow cool air. How long ago did the thermostat get replaced?
You can test your heater core by feeling the 2 hoses. They should both be warm to the touch. If one is and other isn't, then the heater core needs replaced. This is a costly repair though so eliminate all other possibilities first.
Your coolant level at proper level? This could also cause heater issues and overheating.
Friday, November 14th, 2008 AT 1:53 AM
