1997 Chrysler Concorde coolant boils over and running hot
BIGWILL74
  • 1997 CHRYSLER CONCORDE
  • 6 CYL
  • FWD
  • 120,000 MILES
My coolant boils over in the coolant tank.I change the thermostat and I see no leaks around the coolant hoses. But it's still runs hot, and there is no leak present around the water pump.
Monday, October 6th, 2008 AT 5:36 PM
  • 109,885 POSTS
Hi:
Most likely, the rad is plugged and not allowing the coolant to circulate properly. Have it flushed and I recommend replacing the upper and lower hoses at the same tim.
Tuesday, October 7th, 2008 AT 10:32 AM
