A freeze plug is a thin steel plug designed to pop out in the event the coolant freezes. What you need to do is pry it out using an old screw driver or something similar. Once it is out, clean all the corrosion from the engine block where is was.
After that, you have two choices. You can get another steel plug and tap it back into place which is easy if there is access, or you can get a rubber replacement. They basically are a rubber plug with a bolt through a steel outter plate and a bolt that when tightened, expands the rubber creating a water tight seal. I think they are easier to use, but that would be up to you.
SPONSORED LINKS
Sunday, February 28th, 2010 AT 1:01 AM
