1996 Chrysler Concorde
AMANDA21
  • 1996 CHRYSLER CONCORDE
Engine Cooling problem
1996 Chrysler Concorde 6 cyl Front Wheel Drive Automatic
My car starting overheting the other day, and I had gotten a brand new thermostat put in, and put antifreeze and everything in it I let it run for about 15 or 20 mins and it was fine, so I went to drive of and as soon as I started to drive the car started to overheat what could this possibly be?
Monday, June 23rd, 2008 AT 12:03 PM
DOCFIXIT
  • 18,828 POSTS
Do the cooling fans come on?
Monday, June 23rd, 2008 AT 12:24 PM
JAYLEE0712
Did you happen to crack the bleeder valve on the water outlet? If not, that is one place to start. If so, check to make sure the cooling fans are coming on ther are no coolant leaks.
Friday, August 21st, 2009 AT 10:32 AM
