1999 Chrysler Cirrus Overheating
BELIEVE1099
Goodmorning! I have a Cirrus 99- 98500 miles. 4dr sedan. k here goes. Last year in the latter part of hot weather my car was overheating and mechanic checked with pressure gage an seen small pin hole in pipe, not rubber. ok it was replaced. conversacion when car was p/u by family member was that antifreeze was to be added.Message was not related to me and then came winter. First freezing weather came in and now car was starting to act up.She didnt want to start so I was told it was the battery ok i purchased a new battery,then 2 weeks go by and car wont start again Strauss mechanic told me it was the starter ok I change the starter.Now the weather is getting worst. the car starts to act up again. Now she wont move. white smoke is coming out.ok I have car towed to mechanic which replaced pipe in the summer.He checks car and sees that in pipe on top where you take pressure cap off its all frozen. My engine is locked. I need a new engine! ok engine is replaced. Now air conitioner dont work all summer. I visitmechanic and live with the heat in the car all summer.I have antifreee in container but see that where the pipe on top where pressure cap is there ppars no antifreeze and its muddy. mechanic feels somethng is going on with antifreeze cause his clients seem to be having same problem with this muddy substance appearing. he cleans pipe and ask me to purchase new cap. ok now just yesterday when I return home from work. I turn off car and I hear this gurgling noise i pop hood and the resvoir to hold antifreeze and boiling like crazy,engine is hot.Before I go and tell the mechanic where I want to put my foot, what do you think is the problem. I just paid off the car note and paid $1700 plus all other new parts to keep the car.Please help me get this rectified.
Sep 12, 2007 at 1:17 AM
  • 75,988 POSTS
[quote:6e233f7eda="believe1099"]Goodmorning! I have a Cirrus 99- 98500 miles. 4dr sedan. k here goes. Last year in the latter part of hot weather my car was overheating and mechanic checked with pressure gage an seen small pin hole in pipe, not rubber. ok it was replaced. conversacion when car was p/u by family member was that antifreeze was to be added.Message was not related to me and then came winter. First freezing weather came in and now car was starting to act up.She didnt want to start so I was told it was the battery ok i purchased a new battery,then 2 weeks go by and car wont start again Strauss mechanic told me it was the starter ok I change the starter.Now the weather is getting worst. the car starts to act up again. Now she wont move. white smoke is coming out.ok I have car towed to mechanic which replaced pipe in the summer.He checks car and sees that in pipe on top where you take pressure cap off its all frozen. My engine is locked. I need a new engine! ok engine is replaced. Now air conitioner dont work all summer. I visitmechanic and live with the heat in the car all summer.I have antifreee in container but see that where the pipe on top where pressure cap is there ppars no antifreeze and its muddy. mechanic feels somethng is going on with antifreeze cause his clients seem to be having same problem with this muddy substance appearing. he cleans pipe and ask me to purchase new cap. ok now just yesterday when I return home from work. I turn off car and I hear this gurgling noise i pop hood and the resvoir to hold antifreeze and boiling like crazy,engine is hot.Before I go and tell the mechanic where I want to put my foot, what do you think is the problem. I just paid off the car note and paid $1700 plus all other new parts to keep the car.Please help me get this rectified.[/quote:6e233f7eda]
So we've replaced all that goodies huh! Okay -nothing was mentioned about a thermostat.
What was causing the white smoke,did they rule out the headgasket/block/head for leakage.
To nail this problem have a block and pressure tests, Could air lock in the cooling system, try bleeding out might work, see below:
BLEEDING COOLING SYSTEM:
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks
Good Luck
Sep 16, 2007 at 7:09 PM
Suggested Repair
Pressure-test the cooling system and engine block to check for head gasket, head, or block leakage. Verify the thermostat, coolant level, and radiator cap, then bleed air from the cooling system after refilling with the correct 50/50 coolant mixture.
Conversation Summary
A 1999 Chrysler Cirrus with about 98,500 miles had repeated cooling problems: a leaking metal pipe, frozen coolant, a locked engine that was replaced, muddy coolant, and boiling in the reservoir after shutdown. The expert noted that the thermostat was not mentioned and asked whether head gasket, head, or block leakage had been ruled out as the cause of the white smoke. Recommended checks were block and cooling-system pressure tests and bleeding trapped air from the system.
