1996 Chrysler Cirrus Overheating
GLORY.GLORY
I have a 1996 Chrysler Cirrus 6 cylinder..with 174,000 kilos I have had numerus problems of late...had to have the fuel pump replaced, sensor for the engine, distributor replaced and now the power sterring is gone....i have a leak but when I put in more fluid it doesn't help much.
My problem today is that the engine light is on and the car is smoking...not from the rad but under the hood and the temperature gauge is maxed out hot after 30 minutes of driving. All fluids are good.
Help, what is wrong and Thanks in advance.
Feb 21, 2007 at 6:27 AM
SERVICE WRITER
  • 9,123 POSTS
Well you need to fix the powere steering leak for sure, the smoking may be power steering fluid burning. If the belt is getting wet it may be slipping and causing the waterpump to not turn and therefore running hot.
Feb 21, 2007 at 10:07 AM
Suggested Repair
Repair the power steering leak first. Check whether leaking fluid is wetting the drive belt and causing it to slip, which can stop the water pump from turning and make the engine overheat. The under-hood smoke may be burning power steering fluid.
Conversation Summary
The owner of a 1996 Chrysler Cirrus reports an illuminated engine light, under-hood smoke not coming from the radiator, and the temperature gauge reaching maximum after about 30 minutes of driving. Coolant and other fluids are reported full, and there is also a power steering leak that adding fluid does not resolve. The expert says the leak should be repaired and that burning power steering fluid may cause the smoke; fluid on the belt could make it slip so the water pump does not turn, leading to overheating.
