The brake drums on my 2005 sebring will not come off, Is the rear brake drum held on by the hub nut or seperate like my earlier chrysler cirrus?
Aug 8, 2006 at 3:26 AM
The rear drum usually sits on the lug studs and may also be held by a detent screw. Apply penetrating oil at the hub flange, back off the star adjuster through the rubber plug on the backing plate, and carefully tap or pry the drum free without gouging the shoes.
The owner of a 2005 Chrysler Sebring could not remove the rear brake drums and asked whether they are retained by the hub nut or sit separately as on an earlier Chrysler Cirrus. Advice was that the drum typically sits on the lug studs, while expanded shoes, corrosion, or a detent screw can hold it. Penetrating oil freed the drum; backing off the adjuster and careful tapping or prying were also suggested.
