2004 Chrysler Sebring Brake Lights Out
NORMS
My stop lights do not work at all. All the fuses seem to be OK (none are blown) and all the lights are OK also (no blown elements). Seems to be a sensor problem? Is this something that could be fixed by a car repair "novice" or should this be looked at by a mechanic?
May 29, 2006 at 9:47 AM
LSUSSEL
  • 252 POSTS
For me to be able to assist you, it is absolutely necessary for you to include the make, model, year and mileage of your car.
May 30, 2006 at 1:53 PM
NORMS
I have a 2004 chrystler Sebring LX with 68,000 miles.
May 30, 2006 at 4:47 PM
LSUSSEL
  • 252 POSTS
Well this sounds like a electrical issue, you should be able to do this yourself. Check the voltage on the wires running to the brake lights and see if there is any power - voltage going through or if the line is dead and let me know, we can go from there.
-lee
May 30, 2006 at 11:52 PM
Suggested Repair
Check voltage at the wires to the brake lights to see whether power is present or the circuit is dead, then continue diagnosis from that result.
Conversation Summary
The owner of a 2004 Chrysler Sebring LX with 68,000 miles reported that the stop lights do not work, although the fuses and bulbs appear good, and asked whether a sensor might be at fault. The expert said it sounds like an electrical issue that the owner can check and advised testing the brake-light wiring for voltage.
