1997 Chrysler Cirrus won't start
MARKDECK
  • 1997 CHRYSLER CIRRUS
  • 6 CYL
  • FWD
  • 12,000 MILES
Car will turn over but start. No spark.
Friday, January 22nd, 2010 AT 9:44 AM
CARADIODOC
  • 33,916 POSTS
You didn't check for fuel pressure, did you? If not, you'll be diagnosing the ignition system and you won't find anything wrong.
If you did check for fuel, include that in the list of symptoms and clues so we can help you diagnose the problem as efficiently as possible.
Caradiodoc
Saturday, January 23rd, 2010 AT 4:09 AM
MARKDECK
I checked for fuel its seems fine. I pulled a spark plug to see if I could see spark. No spark.
Saturday, January 23rd, 2010 AT 11:41 AM
CARADIODOC
  • 33,916 POSTS
To be sure we're in the right circuit, see if you can find the wires on the back of the alternator. There will be two small ones. Hook a voltmeter or test light to one of them, and set it so you can see it from inside the car.
When you first turn the ignition switch to "Run", you should see the test light turn on for one to two seconds, then turn off. It must turn on again when you crank the engine. If it does not, the circuit that powers the coil(s), fuel pump or pump relay, injectors, alternator field, and oxygen sensor heaters is dead. All these items are fed from the Automatic Shutdown (ASD) relay.
If that ASD relay is turning on during cranking, you do indeed have an ignition system problem. This is relatively rare; the trigger circuit gives a lot more problems. If the relay does not turn on during cranking, suspect the camshaft position sensor. Check for diagnostic faut codes first. They will lead you to the circuit with the problem.
Caradiodoc
Sunday, January 24th, 2010 AT 3:44 AM
