1997 Chrysler Cirrus car turns over but will not start
FLYERS80
MEMBER
1997 CHRYSLER CIRRUS
4 CYL
FWD
AUTOMATIC
134,523 MILES
Is was told that it need a timeing belt. But the is a sticker on the motor saying that one was put on at 89.000 miles. It has a 134.000 on it now. I can hear the fuel pump come on when I turn the key on. Im not sure where to start to get it runing. Thanks Pete
SPONSORED LINKS
Sunday, June 14th, 2009 AT 10:05 AM
DOCFIXIT
MECHANIC
Hi
Does engine turn over faster than it used to?
Check for spark and spray some carb cleaner into throttle body see if it fires?
Let me know
Thanks for donate
Monday, June 15th, 2009 AT 3:00 PM
FLYERS80
MEMBER
It seems to turn over low. I got spark and used carb cleaner. Did not fire. I have a new battery. Thanks
SPONSORED LINKS
Tuesday, June 16th, 2009 AT 4:38 PM
DOCFIXIT
MECHANIC
So it is turning over slower than normal? Pull the plugs and check compression
Tuesday, June 16th, 2009 AT 4:48 PM
FLYERS80
MEMBER
I went back and checked for spark. And I dont have any on all plugs.
Wednesday, June 17th, 2009 AT 7:33 AM
DOCFIXIT
MECHANIC
Is it every other plug not firing? If yes Ohm check wires if good coil maybe faulty
