1996 Chrysler Cirrus Car Not Starting
HABRYCHJ
  • 1996 CHRYSLER CIRRUS
  • 6 CYL
  • FWD
  • 50,000 MILES
On this car I have replaced most of the components that would cause the car not starting. I am not getting any OBD2 codes from the computer.
A mechanic suggested that the car alarm might be causing the problem. I.E. Disabling the car from starting.
How can you reset or disable the alarm so that I can see if this is the problem?
Thanks
Sunday, March 8th, 2009 AT 5:26 PM
What is it doing- Is it cranking over and refuses to start?
Sunday, March 8th, 2009 AT 5:34 PM
HABRYCHJ
Yes, the car cranks but does not turn over.
The car had been sitting out in the open for 2-3 months.
I've replaced the battery, plugs, wires, cap and rotor, but still no spark to the plugs.
Sunday, March 8th, 2009 AT 5:43 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Sunday, March 8th, 2009 AT 5:47 PM
