You should have checked the wires going to the distributor before you replaced anything. The dark green wire with the orange stripe should be hot with the engine cranking. The black wire with the gray stripe should have a pulse on it during cranking. I can't tell what circuits you checked.
SPONSORED LINKS
Friday, March 21st, 2008 AT 2:55 PM
