engine that is overheating?
85,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
300OVERHEAT
I have the car listed above engine that is overheating. I have pressure tested and confirmed there is no loss of coolant. I have removed the thermostat and bench tested to verify it is operating normally. I removed both hoses from the radiator and completely flushed it with a garden hose to verify the radiator has no debris and water is flowing through it. I did a combustion leak test and there is no change in color of the fluid. I also replaced the timing belt and water pump as the belt seemed stretched slightly and I suspected it was not turning the water pump. I verified both fans are operating on both high and low settings. While the vehicle is overheating, I can turn the heater on, and it will lower the temperature to normal operating temperature. I’m kind of stumped at this time as I have completely ran through the cooling system and not seeing anything out of the ordinary. I would like to note I’ve burped all the air out of the system as well...
Aug 6, 2023 at 11:12 AM
  • 55,758 POSTS
It sounds like you covered all the bases. The only thing I can tell you is that the block tester (chemical) is about 75 percent accurate. Also, do you have blockage externally on the radiator like a plastic bag stuck between the radiator and condenser? Please go over this guide:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Can I ask if the engine loses coolant? Are the fan blades damaged?
Aug 7, 2023 at 6:21 AM
  • 55,758 POSTS
Anything?
May 6, 2024 at 5:35 AM
