2000 Chevy Venture Reverse Lights Out
INSPECTOR GAJIC
Make: Chevy
Model: Venture
Year; 2000
Mileage: 224000
Engine size: 3.4L
The reverse lights on my van do not work, I replaced the bulbs and checked all fuses, and didn't find any problems there. What other steps do I need to make the repairs needed?
Oct 2, 2007 at 12:46 AM
  • 75,988 POSTS
Put key to On position-remove bulb put test light in the center contact-ground test light-do you have power-if not start at the transmission neutral safety safety switch at reverse contact, got power-check the wire between it and bulb socket.
Got power at the bulb-you lost the ground wire.
Oct 2, 2007 at 3:17 AM
Suggested Repair
With the key on, test the reverse-bulb socket center contact for power. If there is no power, check the reverse contact at the transmission neutral safety switch, then the wire from that switch to the socket. If the socket has power, repair the lost ground wire.
Conversation Summary
A 2000 Chevy Venture with a 3.4L engine and 224,000 miles has reverse lights that do not work. The owner replaced the bulbs and checked the fuses without finding a problem. The expert advised testing for power at the bulb socket with the key on, then checking the neutral safety switch reverse contact and the wiring to the socket if power is absent, or repairing the ground if power is present.
