1998 Chevrolet Venture OBD Port
KEVI8537
1998 chevy venture LS , 3.4 ltr engine. 135k miles Obd connector! Any advise? I live in a metro area that requires state inspections. Last year I was informed that my connector was not functional,and that the following year it would not pass inspection unless this was repaired. What is involved in this? Just the connector or does it get more complicated? Time running out!
May 11, 2007 at 4:03 PM
SERVICE WRITER
  • 9,123 POSTS
I would start on the simple side and check the fuse.
May 11, 2007 at 4:12 PM
SERVICE WRITER
  • 9,123 POSTS
The dlc is a port that the scaner can communicate with different computers within the truck, the circuit is powered by a 15 amp blue fuse. If your cigar lighter doesn't work, it very well may be this fuse.
Look on the pass. side fuse box
May 12, 2007 at 12:32 AM
KEVI8537
Thanks for all your assistance. As it turns out it was as simple as a 15 amp {cigar) fuse. I still dont understand why they couldn't have given me that info at the last state inspection. Thanks again Paul! :D
May 13, 2007 at 6:32 AM
SERVICE WRITER
  • 9,123 POSTS
They didn't give you the information because they are inspecting, not diagnosing. Besides, it ain't always as simple as a fuse.
May 13, 2007 at 10:40 AM
Suggested Repair
Check the 15-amp fuse that powers the data link connector, often shared with the cigar lighter, in the passenger-side fuse box and replace it if blown.
Conversation Summary
A 1998 Chevrolet Venture failed state inspection because the OBD connector was not functional. The expert advised checking the 15-amp fuse that powers the data link connector, noting it may also feed the cigar lighter and is located in the passenger-side fuse box. The owner later confirmed that replacing that fuse restored the connector.
