2001 Chevy Venture A/C Blowing Hot Air
2001 CHEVROLET VAN
CLE68
I have a 2001 Chevy Venture blowing HOT air. Refrigerant shows normal operating range. Compressor is working. Blower is working. Temperature gets hotter when turn knob from cold to hot. Fuse is good. What else could be wrong? I have wondered about a relay of some sort. Can you please offer some suggestions? Thanks!
Jun 19, 2007 at 4:14 PM
2CARPRO JACK
  • 11,533 POSTS
Most likely the blend door actuator.It is an electric motor that moves the temp door from hot to cold, located under the dash on the outside bottom of the hvac plenum
Jun 20, 2007 at 5:45 AM
