2002 Chevy Venture Radiator Leak
THEAVNER
I have a 2002 Chevy Venture minivan, 3.4 liter engine with 55,000 miles. I have a coolant leak in the lower right side of the radiator which I believe is coming from the gasket where the aluminum radiator tubes join with the plastic side. I thought about adding prestone super leak stop to close the leak but I did not know if this type of product will cause problems with my cooling system. Is is safe to add leak stop to the cooling system or will this create a new set of problems?
Thank you
Feb 1, 2007 at 11:37 AM
SERVICE WRITER
  • 9,123 POSTS
NNNOOOOOOOOOOO!!!!!!!
https://images.2carpros.com/forum/automotive_pictures/30961_scarry_1.jpg
Don't do it!!!!! Fix the leak. The problem with stop leak is isn't isn't too smart, it thinks any small passege inside the motor or t-stat or radiator or heater core is a leak and lugs that up too.
Feb 1, 2007 at 9:50 PM
Suggested Repair
Do not add Prestone Super Leak Stop. Repair the radiator leak properly so stop-leak does not clog small passages in the engine, thermostat, radiator, or heater core.
Conversation Summary
The owner of a 2002 Chevy Venture with a 3.4L engine asked whether Prestone Super Leak Stop is safe for a coolant leak at the lower right radiator, where aluminum tubes meet the plastic tank. The expert strongly advised against stop-leak and said to fix the leak, because the product can clog small passages in the engine, thermostat, radiator, and heater core.
