2002 Chevy Venture Coolant Leak
CHEVROLET
HEAVNER
  • 6 POSTS
I have a 2002 Chevy Venture minivan with 52,000 miles. Recently it started to leak dex-cool coolant at night when the temperature drops down to around freezing. In the mornings, there is a small puddle of coolant on the garage floor near the center of the engine (slightly to the passenger side) of where the oil pan drain plug is located. To my knowledge the leak does not occur in the daytime or while the engine is running. It is hard to see where the leak is coming from but it appears to have dripped down the engine block from somewhere. It is not a the radiator hose. Please help!
Dec 10, 2006 at 2:51 PM
GARFIELD
  • 197 POSTS
You may want to give a good look at the intake manifold gaskets, I have replaced quite a few gaskets on new chevy's lately. Another common problem is the upper inlet plenum that cracks.
Dec 10, 2006 at 9:20 PM
Suggested Repair
Inspect the intake manifold gaskets and the upper inlet plenum for cracks, both common Dex-Cool leak sources on this Chevrolet.
Conversation Summary
A 2002 Chevy Venture with 52,000 miles leaks a small amount of Dex-Cool overnight when temperatures drop near freezing, leaving a puddle near the center of the engine slightly toward the passenger side of the oil pan drain plug. The leak is not seen while running or during the day and does not appear to come from a radiator hose. The expert recommends checking the intake manifold gaskets and a cracked upper inlet plenum.
