1998 Chevrolet Cavalier Coolant Leak
Suggested Repair
Have a mechanic pressure-test the cooling system so the leak location becomes obvious. If coolant is coming from the water pump weep hole, replace the water pump.
Conversation Summary
The owner of a 1998 Chevrolet Cavalier with 122,000 miles reports an unidentified coolant leak and has been told it could be freeze plugs, a head gasket, or the water pump weep hole. They do not think it is the head gasket because a recent oil change showed no contamination or other typical signs. An expert recommends pressurizing the cooling system to reveal the leak and says coolant from the weep hole indicates a failed water pump. A second owner mentions a 1999 Chevrolet Malibu losing coolant weekly with no visible leak and a flickering AC light, but no diagnosis was given for that car.
