1999 Chevrolet Venture Intake Coolant Seep Fix
LEWIS9996
1999 Chev. Venture Van 108,000 miles. Automatic 3.4 V6 engine. Lower intake starting to seap coolant. If not addressed what all could happen?
Jul 23, 2007 at 12:49 PM
ROCKWOOD84
  • 103 POSTS
the intakes will seep at first then will seep a little more then one day it won't be a seep anymore. it will be a leak which will let coolant in the oil and it will have a fluctuating temp gauge because coolant is not pressurized anymore. the problem will only get proggresively worser until it won't run without running hot risking cracking a head. if it is only the intake gasket seeping you could just get away with a set of intake gaskets.if you do it before it runs hot . the head gaskets are alot tougher to blow. these motors are a pain to work on because of the fact that you have no room under the hood to work. it will probably cost you around $600.00 to get it done in a shop. or if you are mechanically inclind you can get a manual and put the intakes in yourself. the upper gasket set runs about $50.00. but i would get the intakes done pretty quick.
Aug 14, 2007 at 6:56 AM
Suggested Repair
Replace the lower intake gaskets promptly, before the seep becomes a leak and the engine overheats. A shop repair is estimated around $600; a mechanically inclined owner can do it with a manual and an intake gasket set.
Conversation Summary
The owner of a 1999 Chevrolet Venture with a 3.4 V6 reports the lower intake beginning to seep coolant and asks what can happen if it is ignored. The expert says seepage will worsen into a leak that can put coolant in the oil, cause a fluctuating temperature gauge, and lead to overheating that risks cracking a head. Intake gaskets should be replaced soon, at roughly $600 in a shop or as a DIY job with a manual and about a $50 gasket set.
