1999 Chevy Venture Window Stuck
KLH2167
I have a 1999 Chevy Venture 90,000 miles 3.4L engine the drivers and passengers side power windows have been moving slow for a couple of months. Just this past week the passengers side has been really slow up and down. Now the passengers side window went down but would not go back up. I checked both switches with a test lights and they both work. I replaced the window motor and it still doesn't work. Do you know what could be wrong with it? Thanks.
Feb 4, 2007 at 4:45 AM
CHEVY22
  • 1,375 POSTS
the window regulators are faulty , cable operated and they bind, if you pull the door panel again you may see a broken or bound cable on both
jim
Feb 15, 2007 at 11:11 PM
MAROS
My window was slow (well still is slow) to go up or down. I have to move it with hand in order to continue. The arm that holds the glass is probably worn out. Then it got completely stuck open - the switch on door went.
This is apparently very common item to break. It costed me 80$ on ebay or 160$ at the dealer.
They are easy to change.
I hope your window works soon
Nov 14, 2007 at 4:49 AM
Suggested Repair
Inspect the cable-operated window regulators for bound or broken cables, and replace the regulator if the cables or glass arm are worn. Both front windows may be affected.
Conversation Summary
A 1999 Chevy Venture had slow power windows, then the passenger window stuck open. The switches tested good and a new window motor did not fix it. The expert said the cable-operated regulators can bind or break and should be inspected. Another owner reported the same common regulator failure and said replacement is straightforward.
