Model: Venture
Year: 2000
Milage:227000
Engine size: 3.4L V6
How do I change Neutral saftey switch on this vehicle and where is it located?
The no-gear condition was traced to the shift cable coming off the transmission shifter arm after the small rubber connector boot failed. Inspect the shift lever and cable, then ask a Chevrolet dealer whether the connector boot is available separately or the cable assembly must be replaced before reconnecting it.
The owner of a 2000 Chevy Venture first asked where the neutral safety switch is and how to replace it. The expert said it is commonly on the transmission where the shifter cable connects and explained that it only prevents starting unless the selector is in Park or Neutral. After the van would not go into gear and the shifter moved with little resistance, the expert advised checking the shifter lever and cable. The owner found the cable disconnected from the transmission shifter arm because the rubber connector boot had broken, and the expert recommended checking with a local Chevy dealer about the part.
