2000 Chevy Venture Cold 1-2 Shift
KENNY 2956
I have a 2ooo chevy venture van 3.4L engine with 115,000 miles. It has a delayed rough shift from 1st. to 2nd. when van is cold and the outsde temp. is below 45 degrees. Problem goes away after 5 or 10 minutes of driving. All other shifts are smooth. The 1st. to 2nd. shift is smooth if it's warm outside. Transmission fluid is in good shape. Any ideas what could cause this ? Thank you.
Oct 27, 2007 at 4:03 AM
2CARPRO JACK
  • 11,533 POSTS
Im not a transmission guy, but I do know GM had a bunch of valve body updates for harsh 1-2 shift around those years.Try calling few trans shops and asking
Oct 28, 2007 at 1:32 AM
Suggested Repair
Have a transmission shop check for GM valve body updates related to a harsh or delayed 1-2 shift on this era of vehicle.
Conversation Summary
A 2000 Chevrolet Venture with a 3.4L engine has a delayed, rough 1-2 shift only when cold and outside temperature is below about 45 degrees. The shift smooths out after 5 to 10 minutes, other shifts are normal, and the fluid looks good. The expert noted GM valve body updates for harsh 1-2 shifts around those years and suggested asking transmission shops about them.
