emergency brake
KIMSCHEVY
I had my e-brake engaged, upon leaving, i disengaged the brake and started to drive away, there was a clicking noise coming from the area of the brake on the inside of the vehicle. It gets louder the faster i drive. I tried to engage and disengage the brake several times to see if that would stop it, but it did not.
Apr 15, 2007 at 8:07 AM
ROCKWOOD84
  • 103 POSTS
the emergency brake was designed to engage when you mash on it once to disengage you push it back down again and let off . something must have broke inside the drum. either take the tire off and pull the drum off each side to see what it was or take it to a brake repair.
Jul 14, 2007 at 10:03 AM
