1999 Chevrolet Venture Coolant Leak
LWESTBROOK78
I have a 99 checy Venture with about 130,000 miles. It's a v-6.
I'm not sure where but, it leaking coolent. However it does not leave a puddle nor can I find any trace of the leak. It is a big enough leak that i have to add about a gallon of water per week to keep it from over heating. Where is the water going?
Jun 8, 2007 at 11:54 AM
SERVICE WRITER
  • 9,123 POSTS
Very high probablity that the intake manifold gasket is leaking. IT is probably burning the coolant, but can also be mixing with the oil or leaking outside and burning off before it hits the ground. Get this taken care of ASAP.
Jun 8, 2007 at 12:50 PM
LWESTBROOK78
How big of a job do you think this is? I would even like a ball park price if you can.
Thanks
Jun 8, 2007 at 1:02 PM
SERVICE WRITER
  • 9,123 POSTS
About $600.00 or so.
Jun 8, 2007 at 1:07 PM
Suggested Repair
Have the intake manifold gasket inspected and replaced promptly. Coolant may be burning internally, mixing with the oil, or leaking and evaporating before it reaches the ground. Estimated repair cost is about $600.
Conversation Summary
The owner of a 1999 Chevrolet Venture with about 130,000 miles reports a coolant leak that leaves no puddle but requires about a gallon of water per week to prevent overheating. The expert says the intake manifold gasket is very likely leaking, with coolant burning, mixing with oil, or evaporating before it hits the ground, and recommends prompt repair at about $600.
