Thanks
2002 Chevy Venture Coolant Mix After Drain
Thanks
The best thing is to do several dump and fills with water and on the last dump add pure coolant and top off, this will give you a 50/50 mix.
Here is a guide to help you get the job done.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Refill the motor with water and run it, drain it several times until is pretty mush just water in there. You'll need to let it circulate each time until the temp gets high enough to open the t-stat and access the rest of the system.
If your adventerous, you can remove the t-stat when you do this to get complete circulation witheout getting to temp.
A savvy owner of a truck like yours will keep a very close watch over the next 60,000 miles as a intake manifold gasket leak WILL happen. Various symptoms such as overheating, oil or coolant loss, misfire codes or a yellow slimy appearance on the oil filler cap begins appearing; will indicate the need.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Cheers, Ken
Suggested Repair
Flush the system several times with water, circulating it until the thermostat opens, until the drained fluid is mostly water. On the last drain, add pure coolant and top off so the remaining water creates about a 50/50 mix. Removing the thermostat can improve circulation during the flush. Also watch for intake manifold gasket leak symptoms such as overheating, coolant or oil loss, misfires, or slime on the oil filler cap.
Conversation Summary
The owner of a 2002 Chevy Venture 3.4L drained only about one gallon of coolant even though the manual lists a three-gallon capacity and asked how to achieve a proper coolant mixture. The expert explained that residual coolant remains in the engine block and heater core, recommended repeated water flushes followed by pure coolant topped off for a 50/50 mix, and advised watching for a future intake manifold gasket leak.
