Truck wont start, have power on both sides of injector wires
KAWIKEV
  • CHEVROLET VAN
I have a 1989 chev 2500,350 auto tbi, have spark good feul pressure at carb[will run when primed] injectors have power at all 4 wire[while disconected], seems like an open ground what is next in wiring that could be sending power, or not grounding
Tuesday, November 27th, 2007 AT 2:20 AM
2CARPRO JACK
  • 11,533 POSTS
One side should be voltage, the PCM grounds the injector to make it work. Check wiring for rub through to the PCM. Might be a bad PCM
Tuesday, November 27th, 2007 AT 5:37 PM
