Engine Performance problem
1995 Chevy Van V8 Two Wheel Drive Automatic 180k miles
Have replaced TPS, Fuel filter, fuel pressure regulator. Cap wires, plugs all new. It will start and idle for a bit slightly rough, not bad though. I can feather the pedal and rev it but it will not accelerate in gear and I have to get on and off the gas to make it move at all. I can see the fuel coming out the injectors on the throttle body and it seems even and increases with the pedal but it will die if I attempt to slowly rev it up only a fast rev will work.
Jul 2, 2010 at 3:58 AM
