Buzzing noise, loss of power when coasting to a stop
2003 CHEVROLET VAN
135,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
GTWPKW
Intermittent problem, only happens when I'm pulling into a parking space or slowing below 5-10 mph about to brake to a stop. ABS-type buzzing noise that stops when I press brake or accelerator, then brake pedal feels harder. Also steering seems a bit harder while it's buzzing, almost like engine has died, but it doesn't die and no lights come on. Happening more often - several times/day, always under 10 mph.
Only other symptom is a couple hard starts, also intermittent - everything else ok.
Dealer cleaned throttle body, "reflashed" computer (these didn't help), and suggested air control motor (not done yet).
Apr 5, 2015 at 12:21 PM
WRENCHTECH
  • 20,761 POSTS
I suspect you have Hydro-boost type brakes that run off the power steering pump and the pump is having a problem. That will effect both brakes and steering at the same time.
Apr 5, 2015 at 7:18 PM
