1984 Chevy Van Squeaky suspension please help
1984 CHEVROLET VAN
CHEVY201984
Suspension problem
1984 Chevy Van V8 Two Wheel Drive Automatic
I own a 1984 Chevy 20 tahoe and every time I get into the car it sounds like the suspension squeaks but only on the front axel; and the same thing happens when I hit a bump or turn the wheel. I tried to correct this by putting grease on the back of the wheel well. I think the problem could also be the bushings. Is there a way to stop the aquecking with all purpose grease?
Please Help
Jan 28, 2009 at 11:52 AM
  • 110,240 POSTS
Hi:
It sounds like bushings to me too. The only thing you could try is spraying a penetrating oil on all bushings to see if that stops the noise. Other than that, they will need replaced. Make sure the ball joints are greased.
Feb 15, 2009 at 4:12 AM
