1996 Chevrolet Silverado Window Tint Peeling Fix
STRYPED
  • 37 POSTS
I have a 96 chevy Silverado king cab. Someone tinted the windows a long time ago and the drivers side tint is peeling and wrinkled. Is this hard to replace myself? Would it be hard to remove the window to tint it outside of the truck?
I have tried tinting a few windows on older vehicles before and could never do it. The stuff always got wrinkled or bubbles I could not remove.
Thanks again!
Sep 19, 2007 at 6:45 AM
BMRFIXIT
  • 19,053 POSTS
[quote:f1442ebebc="stryped"]I have a 96 chevy Silverado king cab. Someone tinted the windows a long time ago and the drivers side tint is peeling and wrinkled. Is this hard to replace myself? Would it be hard to remove the window to tint it outside of the truck?
Thanks again![/quote:f1442ebebc]
i always found it easy to do
thats how i did it clean window
spray it with windex or soap and water get it wet
have the tint ready spray it too (wet)
stick it on glass
and work it from the mid out in all directions
cut it and work all water out
good luck
Sep 19, 2007 at 12:31 PM
Suggested Repair
Clean the glass, wet both the window and tint with glass cleaner or soapy water, apply the film, work from the center outward, trim it, and squeegee out all the water.
Conversation Summary
The owner of a 1996 Chevrolet Silverado king cab asked whether peeling, wrinkled driver-side window tint is hard to replace and whether the glass should be removed. They had previously had trouble with bubbles and wrinkles. The expert said DIY tinting is easy when the glass and film are wet, the film is applied and worked from the center outward, then trimmed and the water worked out.
