1990 Chevrolet Silverado Power Windows
CLOCO1930
  • 6 POSTS
1990 chevy 150000 miles v8 engine. i cant get my power windows to work and i cant find the fuse for it.
Feb 21, 2007 at 5:05 AM
CHEVY22
  • 1,375 POSTS
neither of them work , ???
Feb 21, 2007 at 5:10 AM
CLOCO1930
  • 6 POSTS
none of the windows work
Feb 21, 2007 at 5:11 AM
CHEVY22
  • 1,375 POSTS
fuse should be in the fuse panel in the truck , if you have a test light i would pull the master switch from the left door which just pops out just be careful there are tabs that break , and check for incoming power to the switch and then try power on the other side while moving the switch , if you have power to the switch and back out , next stop is the window motors
Feb 21, 2007 at 5:18 AM
CLOCO1930
  • 6 POSTS
what would the fuse be labeled as andwhats a test light
Feb 21, 2007 at 5:23 AM
CHEVY22
  • 1,375 POSTS
the fuse will be labeled windows , a test light is used to check for power it has a ground lead and the user end is fixed with a ligh and a probe , when its grounded and has power it pops the light on to tell you there is power at the source you are checking
Feb 21, 2007 at 5:26 AM
CLOCO1930
  • 6 POSTS
i dont have a fuselabeled windows in myfuse box unlessthere another fusebox in the car
Feb 21, 2007 at 5:29 AM
Suggested Repair
Look in the truck fuse panel for a fuse labeled Windows. Carefully remove the left-door master switch, watching the retaining tabs, and use a grounded test light to check power into the switch and power out while operating it. If power is present in and out, check the window motors next.
Conversation Summary
The owner of a 1990 Chevrolet Silverado says none of the power windows work and cannot find the fuse. The expert says the fuse should be in the truck fuse panel and labeled Windows, explains how a test light shows power, and advises checking power at the left-door master switch before moving on to the window motors. The owner still cannot find a Windows fuse and asks whether there is another fuse box.
