2000 Chevy Silverado Window Won't Go Up
BWALDRON
Chevy silverado P/u truck year 2000, V6, 72,000 miles
my window switch on the drivers door will not engage & I can't get my drivers side window to go up.
The passenger side window works fine.
Is this a fuse?
Thank you bev
Feb 17, 2007 at 1:37 PM
CHEVY22
  • 1,375 POSTS
do you have the tools to check power , if so pull the switch out and check the drivers window for power , if you have power on both sides pull the door panel , and check the regulator for binding and the motor for power and ground
jim
Feb 18, 2007 at 9:49 AM
Suggested Repair
Pull the driver's window switch and check for power on both sides. If power is present, remove the door panel and check the regulator for binding and the motor for power and ground.
Conversation Summary
A 2000 Chevrolet Silverado owner's driver's window will not go up and the driver's door switch will not engage, while the passenger window works. The owner asked if a fuse is the cause. The expert advised checking for power at the switch, then removing the door panel to check the regulator for binding and the motor for power and ground.
